9one1_
Jun 04, 2013Explorer
Ron Gratz wrote:9one1! wrote:After you reduced the amount of rearward tilt and decreased the number of links under tension,
---The bars pop so loud that they can be heard three towns away. It doesn't do anything for the sway as I pulled over half way home from the last trip and took them off and it wiggled less then with them on.
did you notice any difference in the noise or any difference in the sway stability?
Did you ever try putting Vaseline on the cams to reduce the noise?
Ron
I did Ron as the Reece tech suggested it with the1200lb bars. I think it was actually worse stability wise and really didn't stop the banging at all.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
