RobNLucia's avatar
RobNLucia
SwiftCub Hitch
I have been reading all the posts to see what sway devices might work best with my situation. So, I write to Hensley asking for a price, and also a price for a reconditioned unit. The reply says that Hensley now is testing a new unit that they call the SwiftCub, which is (I guess) a Cub, with a much easier hitch up procedure, using the "the more common chain links to lift the spring bars into position".
Anyone know anything about this product?
  • I believe it has the same lower unit and upper unit (minus the heavy cover) as the regular Hensley hitch. It has the chains instead of the jacks to lift the WD bars up. I do not consider that an improvement although it is probably much lighter in weight. It most likely reduces the cost somewhat also, however it would have to be a quite large reduction for me to bite.
    Barney
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 20, 2026
