Lantley
Mar 20, 2016Nomad
TomHaycraft wrote:
Rather than starting new thread, hope to pick up where this left off.
Having recently 'lifted' trailer to achieve level towing, I need to move from 3 to 4-steps. I'm considering the 4-step TorkLift GlowStep Revolution Scissor Steps w/ Landing Gear. Out of the box, reasonably level sites, dimensions look real good.
My question, where I'm hoping to learn from those who have these installed, how have they worked when dealing with sites with more significant elevation rise or drop? Drop (greater distance from steps to ground), I'm not as worried about, can always put leveling blocks under the step landing gear. When there is a rise (less distance), has anyone found the landing gear to hit too soon? (hope I've described that good enough!)
I do understand your question. The Glow steps will still work. The bottom legs are adjustable and the initial drop is also adjustable.
If you want a simple solution just use a stool as your 4th step.
If you are going to go to the trouble of replacing the steps. I highly recommend using GSR's they are far superior to the typical OEM steps.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
