TomHaycraft
Mar 21, 2016Explorer
Lantley wrote:
I do understand your question. The Glow steps will still work. The bottom legs are adjustable and the initial drop is also adjustable.
If you want a simple solution just use a stool as your 4th step.
If you are going to go to the trouble of replacing the steps. I highly recommend using GSR's they are far superior to the typical OEM steps.
Lantley, I appreciate the response. Will likely place an order for a set of the GSR's today. Next trip is middle of April, will post my experience and thoughts about them. Thanks again.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
