TheFrailer's avatar
TheFrailer
Tadpoles in the grey tank??
OK, so I've been stranded for several weeks waiting on a warranty repair for a blown head gasket for the truck to tow my 5th wheel. I noticed a few days back, during a period of rain, that I seemed to have a frog somewhere in the rig. Didn't give it much thought until I went to dump my holding tanks this morning. As usual, I dump the black tank first, back flush and close it off. Then move on to the grey tank and back flush it.
I should mention at this point that I am full timing and have been leaving the grey tank open and just letting it flow through. I suspect that it might hold a bit of water as the valve never seems to open quite as far as the black tank valve does. That said, I always back flush it when I empty the black tank.
Anyway, as I back flush the grey tank, I notice in the last bit of water leaving (I have the see through attachment) that there appears to be tadpoles in the water. I back flush again and see that there are indeed tadpoles.
So... here's my question.....
What is safe to add to my grey tank that will kill these unwanted parasites?
I also wondered if this were a common problem for anyone else that left their grey tanks open, to flow through?
  • Wow! Better watch those tad poles! You just never know. Being exposed to all the stuff in your holding tanks? You just might have started a whole new breed of animal! Teenage-Mutant-Frogs!
  • I have never had that happen to me...never heard of it...I am sure someone will give you the best solution, but I think I would close off the Grey tank and put some gray water chemicals in it? Leave it sit for at least 24 hours, double dose it?
    I leave my grey open, too. Know I should probably keep it closed, too.
  • Add several cups of bleach and some Dawn dish soap. Fill, let it sit for several hours, drain, repeat as necessary.
Looking for advice before your next adventure? Look no further.25,156 PostsLatest Activity: Aug 16, 2025
