SoTex's avatar
SoTex
Tahoe 3.42 axle 5.3 Vortex and 5,000 lb Jay Flight 26BH
I'm picking up the trailer on Saturday and will be towing it with the Tahoe and a 6,200 lb rating. Although I wanted to be closer to 4,500 on the dry weight, I'm not concerned with the Jayco Jay Flight's almost 5,000 lb dry weight (per yellow sticker even though the brochure shows 4,500 lb).
Any suggestions regarding hitch set up aside from just the typical ball on the under bumper hitch? I've read a lot about Equalizer and other WD/sway contraptions but I'm not sure if I need one or not.
Thanks.
  • Quoted from an earlier/similar question:
    The only conditions that would warrant NOT using WD is that the tongue and trailer weight are below the listed spec in your truck manual, AND if when hitched, the front end of the truck does not rise.
    If the front end rises, then the trailer has taken weight off the front axle and it needs to be returned for safety. Even in the unlikely event you do not really NEED WD, sway control is certainly advised.
  • Most 1/2 ton's hitches are rated for 5000lbs, 500lbs tongue weight, and anything higher requires weight distribution. I had towed a 4000lbs TT with my 1/2 ton silverado, and used an Equalizer brand W/D setup, since it incorporates sway control.
    Do you NEED W/D for that setup? Need is a strong word, but I think most here would recommend. Sway control IMHO is required.
    edit: Remember, you can easily add 1000lbs just from propane, gear, etc into the trailer. So don't forget you will be heavier once loaded.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 10, 2026
