johndeerefarmer's avatar
johndeerefarmer
Explorer III
Oct 08, 2017
Tank or tote for use with Macerator
What is my best option for dumping my tanks using a Macerator? Go ahead and buy a Barker tote and drag that to the dump site or get some kind of tank for the back of the truck?
Do they makes specific tanks to do this with long drain hoses? Or do you have to engineer your own setup?
Thanks
  • johndeerefarmer wrote:
    Thanks for the responses. I don't think I can lift a 7 gallon container from the truck so I need something that stays in the truck. I have several plastic spray tanks from 15-35 gallons but they all have only a 5/8" garden hose outlet. Even with the macerator I think I would need a bigger outlet.
    What size is the hose on a tote?
    I will also look into a 30 gallon drum as that would be ideal.
    RV Waste tote has a standard 3" hose ---and you can connect another standard RV sewer hose to it so you can reach dump station.
    Open vent on tote and most will just drain out...then tilt tote to complete dumping
    No problem. You just need a sewer hose long enough to reach from the tote in the bed to the dump hole. Hook that up then lift the tote from the other end. It's not that heavy when you're only lifting one side.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I too like the idea of a full hook up and use them as much as possible.
    For macerator use you can use a tote or a tank. a 55 Gallon drum with a female hose fitting on the vent (small) opening will usually work epically if you have 36 gallon tanks. Outfit the larger opening with the proper cut off valve and I'd use RV type 3" hose at the dump station.
    But the totes work well.
  • Thanks for the responses. I don't think I can lift a 7 gallon container from the truck so I need something that stays in the truck. I have several plastic spray tanks from 15-35 gallons but they all have only a 5/8" garden hose outlet. Even with the macerator I think I would need a bigger outlet.
    Engineer your own setup ... I use 7 gal Aquatainers marked for GW / BW use. Just set 'em empty in the back of the truck and pump macerated black or grey water directly into them, the most you have to do is lower a full tank weighing 60 lbs from the tailgate to the ground at the dump station. Easy to fully empty, easy to flush out, easy to store, and inexpensive ... everything a tote isn't.
    FWIW, I ran switched 12 vdc from the battery back to where the waste gates are locating, wiring to a standard Bargman connector. Since this is a switched feed that means I can preset the macerator's switch to on and control it while standing at the back of the truck where I can monitor the tanks as they fill. It's all too easy. :B
    Pics are in my gallery.
  • I engineered my own setup for use with my macerator pump. A 30-gallon plastic drum ($10), 1-1/2" dump valve, and 12' of sump pump discharge hose. The drum is strapped in the truck bed resting on blocks so it doesn't roll.
  • Best option.....Full Hookup site....either dump/pump at leisure
    Next best..drive to dump station and dump using 3" sewer hose on way out of CG
    Macerator great for 'pumping' directly into cleanouts at home
    Macerator OK for pumping into 'tote' to be dragged to dump station
    OR pumping into tote in back of truck/then drive truck to dump station and dump tote using add'l hose connected to tote hose while still in back of truck
    Piece of cake for a John Deere Farmer :B
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
