mmc100bb's avatar
mmc100bb
Tankless Hot Water
I have a 2014 Keystone Sprinter. I am interesting in replacing my hot water heater with a tankless one. Does anyone have recomendations on the best model ones to buy?
❚ Did you see the FTS "Announcement : READ BEFORE POSTING HERE"?
    Forum Technical Support (FTS) is reserved for questions related to the use of the Open Roads Forum sites,
    member profile and photo testing, and for reporting account issues. Please avoid using FTS for RV related
    questions. Instead, select the Sub-Forum which corresponds to the subject of your topic. Thank-you!
    Moved from FORUM TECHNICAL SUPPORT
  • Tankless water heaters perform best when water volume delivered to the input is robust and reasonably constant. In RVs this may not be doable, and the result is temperature fluctuations and general bad performance. The one in my house is great, but knowing how they work (and what they need to perform well) I would not want one in an RV.
  • azdryheat wrote:
    The diesel pushers use an Aqua Hot system. Try them.
    I bet you Diesel pusher rides a whole lot smoother than my travel trailer.
    Shocks are a wonderful thing.
    Some appliances can not withstand the jarring.
  • when we had our store people thought the tank less way was the cats meow but it turned out to be an expensive mistake. sure you save space and weight but they don't work that great in a RV
  • Tankless is thankless. RV manufacturers are discontinuing tankless water heaters. Swim with the tide.
  • Do yourself a favor and search here qnd on the other RV forums on tankless water heaters. There are lots of comments, not many very good.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 18, 2026
