bighatnohorse
Jul 23, 2014Explorer II
atreis wrote:
RV water heaters have a check valve that keeps hot water from flowing out their inlet, and this can fail. In that case, hot water can get drawn out of the inlet causing the temperature to alternate between hot and cold when just the cold is on.
Another possibility to check into - it's more likely to be the case if you have this experience with more than one faucet.
This might be the case.
My wife mentioned that the bathroom faucet also would run warm and cold.
And it is just as you state - it will alternate between hot and cold when just the cold is on.
So. . .I guess that I need to find the hot water heater inlet check valve?
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
