svt440's avatar
svt440
Tear drop travel trailers, do they sway?
I owned a 28' rear kitchen travel trailer that liked to sway (even with sway bars). I then moved to a 32' fifth wheel that has spoiled me and tows like a dream (this is my current rig). I'm considering down sizing to a Winnebago Winnie Drop 170S (2800lbs) and they look like they may have a lower center of gravity. If I downsize to an F150 and pull a Winnie Drop, at freeway speeds will it want to sway like any other travel trailer or not? Thanks!
  • Exactly. I've read of individuals towing open utility trailers (2000lbs) where the tongue weight is too light and they are experiencing frequent sway events. Proper loading on all trailers is key!
    A F150 with a tear drop trailer will be a good combo but be vigilant on making sure you are loading it with enough tongue weight and loading balanced, side to side. Do not expect a sway control device to correct a frequent sway problem. Adjust loads to avoid sway first. A sway control device is there for the unique sway event caused by outside forces.
  • Any trailer can and will sway given the right set of circumstances. Light tongue weight can contribute to the problem.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
