NekkidFish's avatar
NekkidFish
Temperature Question
In the upcoming weeks, the night time temps could go down around freezing ... with the day temps being in the 50's.
We have our second adventure scheduled in two weeks, and I worry about the temps at night. :(
Do we need to take steps, or be worried if the temps go down to 32 degrees?
Thanks! Jules
  • rhagfo's avatar
    rhagfo
    Explorer III
    If midday temp get back to the 40's even 30 should not be a problem for a day or two. We have our rig in a storage yard no heat no problem.
  • Our previous '95 Coachmen Class A did fine at -4 deg.F last January, with just a very minor water line freeze up. Your Leprechaun should be fine at low 30's temps.
    No. Only if it gets into the mid 20s for several hours. If the worry factor is there, just leave the furnace and WH on.
  • Only for your personal comfort and, if your furnace is working correctly, only for your wallet because you'll burn more propane. Your water lines will be fine unless the temps go further below freezing for an extended period. You might just disconnect the fresh water hose, if you're connected. Enjoy!
Looking for advice before your next adventure? Look no further.25,174 PostsLatest Activity: Nov 02, 2025
