BenK wrote:
Goal for the the setup when done...is to have the trailer level at its highest
pointing (recommend pointing slightly down), the TV is leveled/WD'd as per
its OEM recommendations, the setup is within and not over the 'actual' ratings
and the tongue should be in the 12%-15% 'actual' tongue weight
This applies to all classes of TV, but the lowest class benefits the most
from this final setup goal
^^^^ This should be a sticky because it's right on.
Sadly, there are many threads on this subject that contain posts of quite dubious value.
