DW-gray's avatar
DW-gray
The Benefits of Weighing Your Tow Rig Twice
So often, RVers will pull up to a scale and get the weight of the tow vehicle's front and rear axles, and the trailer axles. They drive away, and later sit down with their calculator to come up with few safety weight numbers. It either looks good or they may discover a truck axle that's overloaded or maybe they exceed the gross combination weight rating (GCWR). They think that's it and that's all they need to know.
RV Safety and Education Foundation (RVSEF) data indicates that 60 percent of all tow vehicles on the road exceed one or more weight safety ratings. "Many of these trucks exceed all of their ratings," said Walter Cannon, executive director of RVSEF.
The following RV rig reports are based on a real towing combination with a fifth wheel that speaks more volumes than a bunch of words. (Conventional tow rigs may require up to three weigh-ins when using weight distribution systems.)
(The examples below are not my rig.)
Here is all one can know with one weigh-in.
Here is the report with two weigh-ins.
  • Golden_HVAC wrote:
    So was that the readout for your truck and trailer?
    That would put the pin weight around 3,200 pounds on your trailer. Is that including your smart car in the back, or without it? It seems like with the smart car, the pin weight would go down by say 200 to 300 pounds or so.
    Also interesting is that the front axle weight is about 150 pounds higher with the trailer attached. It seems like with the hitch pin centered over the axle and 1" to 2" forward, only a small portion of the trailer pin weight would transfer to the truck front axle. In this case the truck GVW went from 7700 to 10,900 pounds or up by 3,200 pounds. 5% (would be 160 pounds) is transferred to the front axle.
    All of this is very interesting.
    Fred.
    Excellent observations, Fred. It’s certainly observations one would not see with just only one weigh-in.
    No, the example above is not my rig. (I added a note above to that fact.) But you do point out correctly that pin weight is usually reduced when heavy items are garaged in toy haulers. In my toy hauler, the pin weight is reduced by 325 pounds. (From 3,725 to 3,400)
    The reason that there appears to be a sight weight error for the weight shift is likely in the scales. Most scales for heavy weighing only have divisions of 20 or 50 pounds. Therefore, the potential for error is 10 pounds for 20 pound division and 25 pounds for 50 pound division.
  • That gets pretty confusing. I use this site/formula.
    http://www.towingplanner.com/ActualWeights/FifthWheelCatScales
    I try to do my weights twice a year and plug all the information in. I never unhook at the scales. I generally will weigh my truck by itself a day or two before pulling out when I am at a Pilot or Flying J toping off my tanks. Then during one of my first fuel stops down the road pulling the FW I will run across the scales again hooked up. Then I will take the two weight tickets and enter the information into the aforementioned formula.
  • So was that the readout for your truck and trailer?
    Fred.
