fill's avatar
fill
THE FINAL FLASHLIGHT
I just picked up the last flashlight I’ll ever need: the Nebo / Big Larry. Don’t look at it directly; it will temporarily blind you. Instead of individual LEDs it has a yellow plate full of LED chips that puts out 400 lumens. The 2nd setting is softer.
The third setting is just as impressive. It’s a BRIGHT red flasher. The unit has a very strong magnet in its base so that you can stick on steel either to see or be seen beside the road.
The unit is a tube about 7 ½ inches long and runs on 3 AA batteries.
I got mine at a local Drug / Hardware store (It’s a small town.) but I’ve seen it on Amazon for the same $20.
Fill
Subaru. ’94 GoldWing 1500 SE
2012 Roll-A-Home, Eagle 1 trailer
GWRRA, Thousand Trails, IBMC
(We’ve downsized)
  • beemerphile1 you beat me to the explanation. I think the low current flow of LED lights also leads to the dirt problem also. I find I'm popping batteries and rubbing the contacts on my jeans often. The bigger problem I have seen with LED lights is I have them everywhere, therefore I never/seldom use up a battery, they do last forever and the batteries go past their use date and start leaking. Not a problem on the free/cheap ones but when it happens to one of my good ones.... So I try to remember to pop out batteries on a regular bases to check the date on the batteries.
    I have several favorites but none that were super expensive. I have a 3 D cell unit I got on sale at HomeD a couple of years ago for $25 that is the brightest flashlight I have ever owned., 1000+ lumens, it lights up the night. I have a couple pocket flashlights that were in the $10 range, on sale, that I like a lot one is a Coast. I find they make a flashlight that feels and work enough better than the free ones that I will grab them first. Also have a few Maglites in different sized from AAA to D. Oh I also have some head lamps, 3 cheap one slightly better with focused beam.
    Boy I have a lot of flash lights :-)
  • This post seems out of date. Buying a decent LED flashlight was an issue just a year or two ago. That is no longer the case and every hardware store has a selection. I use the cheap $1 flashlights for most uses. When I want a serious flashlight, here is what I want. Power by 2 D or 2 C cells instead of costly low power AA or AAA batteries. I want a low power saver setting and a high power setting in the range of about 500-700 lumens. I want a head that will concentrate and focus the beam and adjust to a wide setting when needed. I can usually find flashlights that meet these requirements at under $10. I think my last purchase was a pair of Duracell brand flashlights from Costco at about $7 each.
  • Have a bunch of these. 1 AA battery, 3 settings and pocket sized w/ a belt clip.
    http://www.amazon.com/UltraFire%C2%AE-300lm-Flashlight-Torch-Adjustable/dp/B006VPPERC/ref=sr_1_15?ie=UTF8&qid=1445354111&sr=8-15&keywords=cree
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 17, 2025
