Patrick45's avatar
Patrick45
The smell of a dead mouse..
We haven't seen any evidence of mice being in the living space of our trailer but now we have a smell of what must be a dead mouse. I suspect the smell originates from the area above the belly membrane but short of taking it all down I would like to start with a cover up to see if/when it dissipates. The only thing that comes to mind are dryer scented sheets.. Does anyone have additional suggestions?
  • Febreze helps. I think a lot of this depends on the person's sense of smell. Mine is not too good.
  • It's happened in my trailer twice. I've never found the culprit either time, and there was never any evidence of them actually getting inside. After about 6 weeks the smell has gone away. I did purchase a de-ionizer to try next time.
  • In my area a mouse will dry up and the smell goes away - not sure that applies to hot/humid environment. Also - mice tend to build nest and those nest tend to stink forever. If you enjoy the smell of coffee you might consider using coffee grounds - they are famous for absorbing various odors.
  • Had a mouse die in our garage (I poisoned it) and it stank. I looked everywhere but couldn't find it. Eventually the mouse desicated enough that it no longer smelled.
    Found it several years later when I moved a work bench.
    Short of taking the underbelly down all you can do is wait - but it will stop smelling eventually.
    Have to wonder though, if it smells that strong, maybe it's bigger than a mouse.
  • I can't help with your smell, but I can suggest how to prevent it from happening again. Keep a mousetrap loaded with peanut butter at all times near any opening where they can get in.
  • Sorry to inform you, the smell will never go away. We had a mouse get in the house and evidently it died inside one of our walls in a bathroom area. For over 4 yeas we had this hideous dead mouse/urine smell in that bathroom. Finally, we decided to remodel and expand the bathroom into another room and the entire 2 rooms were completely gutted. Guess what we found? Yep, the body, and WOW did it smell once the wall was opened up. Got it all cleaned out, bleached the "snot" out of the studs, and eventually sealed up the walls with new dry-wall and insulation. No more smells sense. (FYI...I also sealed those walls so tight, not even air can get into them now ... let alone a mouse!) Smell gone.
    Good luck though with the cover up.
Looking for advice before your next adventure? Look no further.25,151 PostsLatest Activity: Jul 25, 2025
