- atsrmfExplorerNok-Out works
- ferndaleflyerExplorer IIIPut the ozone machine in today for around 8 hours and all signs of odor are gone. Thanks for all the help.
- ferndaleflyerExplorer IIIThat compartment goes all the way through. Got it open today in 95 degree heat. Smell is about gone, maybe,
- maillemakerExplorerWe just had a mouse somehow get down our dryer vent tube from the attic of our home and die in the flex pipe behind the dryer. Clothes came out smelling like death.
I replaced the pipe, and then sprayed Febreze in their liberally and ran a couple of empty loads with no heat. Smell gone.
I would open up the bay, spray it down liberally with Febreeze, and then put a box fan in there and air it out. - ferndaleflyerExplorer IIINot sure which but so far I have disposed of the deceased, scrubbed all signs of it away, sprayed Lysol on the spot, and today I left the doors open on both sides and sprayed it with Fabreeze. Smell is about gone but I will still bring home the ozone machine from our other house next week.
- oldaveExplorerBy the time you try all of these things the smell will most likely be gone
but will you know which one actually worked ?? - MerrykaliaExplorer IIi would use the ozone machine and then place an opened back of charcoal (not the stuff that has lighter fluid already on it. Shut it up for a few days and you should be good to go. Make sure all the residual body part/fluids are gone prior to using the ozone or charcoal.
- ferndaleflyerExplorer IIII happen to have one of those ozone machines at my other house because when we go there it is always musty. I will go get it over the weekend....Thanks everyone.
- gboppExplorerX2 on the Ozone Machine.
- MrWizardModerator
38,771 PostsLatest Activity: Apr 20, 2026
