D_E_Bishop's avatar
D_E_Bishop
Things are FOULED UP BEYOND ALL REPAIR
Yesterday one of my toweds died, at least it seems dead, today I went to the storage yard to get the MoHo and our utility trailer and the key for the padlock on the trailer is in the towed in the hospital, left the trailer and drove the MoHo home. About five miles from the yard I noticed the right side mirror was flat against the side of the MoHo. Stopped and got out to adjust the mirror which required I get off the freeway and then get on an on ramp to adjust the mirror. Finally found a open end wrench and managed to tighten the mirror enough to get home.
Got back in MoHo and started up the on ramp, engine died when I floored it to get up to speed to merge onto the freeway. Engine was a problem all the way home and died going up the hill to the house. I had to stop on a very steep hill and restart the engine. Tried to floor the engine and it started sputtering. Backed off on throttle and got home. Went to move the other towed and when I returned to the MoHo, there was coolant dripping on the pavement.
Turned out to be the vacuum actuated control valve for allowing hot coolant into the heater coil. Thought it was the hose clamp. No such luck it is a $25 valve.
Not enough yet?, we were suppose to leave for the desert with the DGKs for a few days to fix up their Mom and Auntie's cabin. The five days of prepaid camping is non-refundable.
Called our mechanic and he said not to hurry bringing it in as he can't get to it until next week.
I'm going to check the spark plug wires tonight in the dark, mechanic said the fuel system is in great shape(after I spent about a thou to have two new fuel pumps and all new hoses installed.
At least my GP approved a refill for my allergy inhalant medication.
Wife called, she is at the DD's house and they are all going out for diner so I'm on my own for that.
Wish I still drank SMW but DW made me give that up.
Waiting for commiseration and woossa-wossas.
  • If your ignition and fuel systems are good I would check the catalytic converter, they have been known to collapse internally especially after being stored for an extended period. Seen this happen more than once.
  • Back in the day, you could put a pair of vice grips over the hose, just before the heater valve, and pinch it shut. Should still work with newer vehicles, since the valve, when closed, just stops the fluid there, anyway. Not the correct fix, but stuff like that can help you get home. If you pinched one side of the valve and coolant comes out, it's the wrong side, of course. We used to put boiler cutoff valves on the heater line to make sure no hot water snuck past the cable operated heater cutoff to our air conditioning on those hot Georgia summers.
  • I guess my saying "expect the worst, hope for the best and settle for whatever falls in between" sort of fits your day...I also do not go by
    Murphy's law, I go by Schwartz's law, he says Murphy is an optimist.
    Hope all you troubles play themselves out soon...
  • "FUBAR" - Fouled Up Beyond All Repair.....what's wrong with that?
    Kinda like seeing "SNAFU" - in the local newspaper.
  • The saying goes that bad things come in sets of three. But in your case, it sounds like the 4th bad thing wasn't an independent event. It was the start of another set of three. :(
  • Certainly not the day to buy a lottery ticket.
    Hope tomorrow is better!
Looking for advice before your next adventure? Look no further.25,177 PostsLatest Activity: Nov 19, 2025
