ncrowley
Nov 28, 2014Explorer II
We use the Flo Pur RV Pro 10000 water softener. As already stated, it used 2 pounds of ordinary table salt to regenerate. The only issue we have had was with the plastic Y at the outlet port. It broke and we replaced it with a metal one. You flush it after regenerating so there should not be salt that would eat up your drain plug. We put a Y just before the hose goes into the water softener and I get drinking and cooking water there. Some people do not worry about the trace salt in the water. It is the same issue when you use a water softener at home. After we started using the softener, we do not get all the water spots and scale we used to get using the hard water out west.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
