PA12DRVR
Jan 03, 2020Explorer
This is a stamped (U, V, UM, ....) ASME Tank?
I'd suspect that unless you're seeing pitting that you would believe weakens the tank, it's probably fine.
However, given what appears to be the difficulty and expense of replacing it, it might be worth looking around for a tank shop (an industrial tank fabrication shop, not Joe's Propane) with an "R" stamp: they will have a National Board / ASME approved testing program and will likely be able to hook up to the tank, pressure test it in place, and identify if it is suitable for continued use. Might have to pay a bit since most folks with an R stamp think of "tank" in the hundreds of gallons or hundreds/thousands of psi, but an R stamp shop should have a testing program that would indicate continued suitability for use.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 19, 2026
