wa8yxm
Jan 03, 2020Explorer III
I very much suspect your tank is still in excellent condition...
If you are "Just north of Detroit" I know a place in Flint, MI that might be able to help you.. I believe they are on Carpenter road (Exit off I-475) at Dort Hwy
I'd call and check.. They re-cert luggable tanks but the tanks on Motor homes do not need that. I suspect they could replace one if you insist but doubt it is needed. If you work with them you may need your own jack..
I-475 was under construction when I split on Nov-11 and I doubt they are done but there are alternate routes (IE 69 to Dort)
Jacks.. I carry a 12 ton Air/Hydraulic Jack-Jack (Can be operated manually or eat compressed air) from Horrib.. Er, Harbor freight. .and some nice STRONG jack stands (six ton) And a plank (2x12x12 minimum or 2x8x3feet) to put under the jack (Without the plank it punched a hole in a parking lot when the tire store used it to put on new rubber)
Parker Propane Flint
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 20, 2026
