Old-Biscuit
Sep 22, 2017Explorer III
IF an Atwood WH (and it appears some of the THOR CLass C's use Atwood-----course THOR has SEVERAL Class C's) it will have a DUAL on/off panel....one switch for electric and one switch for gas with Fault light between them
Only other way to tell is look on backside of water heater tank near bottom...protective cover over electric element. No cover...no electric
If Suburban (THOR may/may not use??)
There will ne an ON/OFF switch in outside compartment lower left for electric (may be one inside if RV Mfg installed one) and there will be a cover over element behind/below gas valve.
Otherwise it could very well be a GAS Only 6 gallon water heater with DSI (Electronic ignition) which is common install.
IF they look inside outside compartment and see Model Number
Atwood...gas/electric will be a GC6A-10E (gas only G6a-10E)
Suburban..gas/electric will be a SW6-DE (gas only SW6-D)
Warranty
Atwood....2 years from DATE of PURCHASE
Suburban..2 years from DATE of PURCHASE
THOR.....??????
Warranty
THOR.....??????
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 15, 2026
