GWolfe's avatar
GWolfe
Those of you with accumulator/pressure tanks
I'm going to add one to my camper. My only question is what do you do to winterize? I have always just blown air through my lines and dumped RV antifreeze down the drains. Will I need to start running the antifreeze through my lines as well?
  • pianotuna wrote:
    Hi Lawrosa,
    How about the ones intended for reverse osmosis?
    Yes any tank made for potable water....
  • accumulator tank waste of money IMO unless you get a larger tank like used for a HWH... You will not like the results with the tiny ones they sell for RV that hold less then a 1/2 pint of water...
    https://www.homedepot.com/p/8-5-in-W-x-11-5-in-D-x-8-5-in-H-Pre-Pressurized-Steel-Water-Expansion-Tank-DET-5/100677607
    Just need a 3/4 x pex adapter, a 1/2 pex tee, and a small length of 1/2 pex hose...
    IMO youll be happier with the results all for under $50 bucks...
    Im a plumber 35 years....
  • I put a T valve on ours when we had one. Then I could empty out the last bit of water in it.
  • donn0128 wrote:
    The tank should be a bladder type with air on top, water on the bottom. Once you open the low point drains the air pressure should expel the water.
    X2
    I have a valve at the tank that I close after expelling the water then I can pump the antifreeze into the water lines.
  • The tank should be a bladder type with air on top, water on the bottom. Once you open the low point drains the air pressure should expel the water.
