- lawrosaExplorer
pianotuna wrote:
Hi Lawrosa,
How about the ones intended for reverse osmosis?
Yes any tank made for potable water.... - StefoniusExplorerI agree with lawrosa - use a larger tank. Here's the one I put in: 2 gallon pressure tank. It does the trick!
- pianotunaNomad IIIHi Lawrosa,
How about the ones intended for reverse osmosis? - lawrosaExploreraccumulator tank waste of money IMO unless you get a larger tank like used for a HWH... You will not like the results with the tiny ones they sell for RV that hold less then a 1/2 pint of water...
https://www.homedepot.com/p/8-5-in-W-x-11-5-in-D-x-8-5-in-H-Pre-Pressurized-Steel-Water-Expansion-Tank-DET-5/100677607
Just need a 3/4 x pex adapter, a 1/2 pex tee, and a small length of 1/2 pex hose...
IMO youll be happier with the results all for under $50 bucks...
Im a plumber 35 years.... - ScottGNomadI put a T valve on ours when we had one. Then I could empty out the last bit of water in it.
- RCMAN46Explorer
donn0128 wrote:
The tank should be a bladder type with air on top, water on the bottom. Once you open the low point drains the air pressure should expel the water.
X2
I have a valve at the tank that I close after expelling the water then I can pump the antifreeze into the water lines. - donn0128Explorer IIThe tank should be a bladder type with air on top, water on the bottom. Once you open the low point drains the air pressure should expel the water.
Looking for advice before your next adventure? Look no further.25,166 PostsLatest Activity: Sep 30, 2025
