Mike_LeClair's avatar
Mike_LeClair
Thoughts on circulating warm air in the RV?
Hi Folks!
I am curious to read what your various thoughts and theories are on the good, better, best ways to circulate the warm air output from the furnace and supplementary heaters that you use in the RV. We are wintering in Osoyoos, BC and are heating our RV with the furnace and built in fireplace. The RV has a ceiling fan in the living and galley area that I currently have running on slow speed and rotating in a clockwise direction to pull air up to the ceiling. My theory is that the warm air produced by the furnace and fireplace would be pulled up to the ceiling and then follow the ceiling to the outer walls and down to the floor and back up again (at least in theory). The downside is that I feel a chill from a slight air current that I presume is being caused by the running fan. Are there other things that I could or should try to maximize the heat energy from the furnace and fireplace?
Cheers!
Mike
Looking for advice before your next adventure? Look no further.25,200 PostsLatest Activity: Jun 29, 2026
