6_7_tow_rig
Jun 03, 2013Explorer
tightening dump valve handle
My dump valve handles come through the frame and have a metal sleeve around the rod. When they are extended you can then see the actual rod the handle is attached to as it comes out past the sleeve. Is this the part that you can turn to tighten or loosen? How do the valve handles actually tighten. There are no screws on the t handle end so Im guessing you just turn the rod because it probably has threads on the end?. Turning the handle itself does nothing
