- Dog_TrainerExplorer
Dave H M wrote:
The main reason is I am not trying to change carrying capacity I simply want to add some stability to the side to side or roll when loaded. I have about 80,000 miles under my belt with Ride Rite bags and I know their capabilities. The helper spring or Timbens are withing the budget.Dog Trainer wrote:
Thanks for your replies. I am going with the Timbrens.
How come you did not throw air bags into the equation? - kevdenExplorerI have had hellwig helpers on an f150, airlift airbags on a coil sprung chevy avalanche, and now have timbrens on a gmc yukon xl 2500. I like the timbrens the best. My yukon has the quadrasteer system with a dana 60 rear axle. Timbren did not make a helper specifically for this axle, so the helpers are in contact with the axle all of the time. It makes for a rough ride when unloaded, but it tows great. This is not our daily driver so we can live with it.
- calewjohnsonExplorerI have Timbrens on my 2015 F350 DRW...when I installed them, there was about 1/4 inch between the Timbren and the stub... Since I had an empty 100 gallon transfer tank at the time, I added the spacer, it sits on the stops empty (ride is a little pogo), but with fuel in the transfer tank, rides nice. Will be towing for the first time this week with the Timbrens installed....
Cale - NC_HaulerExplorer
calewjohnson wrote:
I have Timbrens on my 2915 F350 DRW...when I installed them, there was about 1/4 inch between the Timbren and the stub... Since I had an empty 100 gallon transfer tank at the time, I added the spacer, it sits on the stops empty (ride is a little pogo), but with fuel in the transfer tank, rides nice. Will be towing for the first time this week with the Timbrens installed....
Cale
I've heard of Ford rolling out new models early, but a 2915 F350 Dually already:B
just playing with you, I know it's a typo because I make so many of them myself, you only missed it by one key:) - 2112Explorer III have been pleased with my Timbrens.
NC Hauler wrote:
Cale
Yeah, I have better than aluminum body and I don't have to use DEF, I can just pee in my own tank. ??
Thanks for the catch.
Cale - Dog_TrainerExplorerMy Timbrens seem to be doing what I wanted. I have about 3/4 inch clearance when not towing and then they are on the axle when I hook up the TT. I have taken the TT about 150 miles so far and the ride is good. So far I am glad I went with the Timbrens.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
