Rice's avatar
Rice
Explorer III
Jun 14, 2017
Tip: "Tractor" fuel = RV diesel
I was refueling at a place that uses a touch-screen for paying at the truck pump. After I swiped my credit card, the following questions appeared:
Tractor fuel: yes no
I pressed "no" because I'm not agricultural or whatever.
Then it said:
Reefer fuel: yes no
I pressed "no" and it came up and said "no fuel" and cancelled the transaction.
I went inside and found out that "tractor fuel" is just regular diesel. So they tried to run my card in there and problems ensued because of their terminal, and I gave up. And at the next place, my card was declined because my credit card company had detected fraud.
The moral of this story: if you're filling your motorhome and see "tractor fuel" on a screen, press "yes."
  • Playtime II wrote:
    Sure? Tractor fuel is for the drive unit of an eighteen wheeler. Tractor fuel incudes commercial road taxes. Refer fuel does not have the taxes. However I believe both are the same blend of diesel minus the dye.
    As a noncommercial, can we use refer fuel?
    No, reefer fuel is just dyed off-road diesel. Because it is used for the refrigeration unit it is not subject to road taxes.
  • Could tractor mean a semi-tractor as in "tractor- trailer" of the over-the-road type?
  • Sure? Tractor fuel is for the drive unit of an eighteen wheeler. Tractor fuel incudes commercial road taxes. Refer fuel does not have the taxes. However I believe both are the same blend of diesel minus the dye.
  • I thought off road use diesel had/ or didn't have a special dye so the feds could sample the fuel and see if it was legal to run on the highway.
    bumpy
Looking for advice before your next adventure? Look no further.25,108 PostsLatest Activity: Jan 30, 2025
