2manytoyz
Apr 15, 2015Explorer II
I have a different input. First, mine is a tandem axle, so I won't tell you how "I think" it might fair versus a blowout on a single axle.
I will tell you the blowouts on my trailer, my BIL's trailer, and a friend's trailer, had NO visual indications of a failure prior to coming apart.
Tire pressure had been checked that morning. No checks or cracks in the sidewalls, tires not overloaded, and trailer not exceeding the 65 MPH rating of ST tires. No warning!
One of my blowouts was violent, shaking the trailer as it came apart. Another had pieces coming off, but never felt it. I had someone pull up next to us, and point towards our trailer. That's NEVER a good sign!
The tire barely slapped the side of the trailer on this one:
This is from another trip:
My BIL's tire failure:
If you look closely, these are all Goodyear Marathon tires.
I've since replaced all of them, including the spare, with Maxxis tires. They are highly recommended on this forum, and my friend who's popped more tires than anyone I know. Even had two fail on a single trip at different locations. He's not had any failure since either.
Make sure you have a filled spare, the capability of raising your trailer since the wheel will be all the way to the ground, and that your lug wrench actually fits the lugs. As stupid as the last part sounds, my trailer has fancy aluminum wheels. The lugs are recessed in skinny holes. It takes a thin walled socket to reach them. I discovered this on the side of a hwy.
https://www.youtube.com/watch?v=yRC-xuGGGHk
I now own a Tire Minder Tire Pressure Monitoring System. VERY easy to install and use. About $200 online. It displays realtime pressure for each tire, and temperature. Sudden pressure loss results in an alarm. The sensors simply screw onto the valve stems in place of the valve caps. The batteries in the sensors are also easy to replace when needed.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
