solman
Jun 03, 2022Explorer
Tire exploded in Florida
Hello All,
I just returned from a round trip to Florida from New Jersey. Towing a Keystone cougar fifth wheel trailer with factory installed Trailer King tires. These tires are made in China and I believe are not up to the rigors of highway travel in the Florida heat. The tire exploded on I-95 without warning. I monitor tire pressure with a tire minder and checked with a pressure gauge before my return trip. The trailer was difficult to control for a moment but I got to the shoulder and put on the spare tire. It Was a harrowing experience on the side of a busy interstate road.
I know that many believe that our poor road conditions are the problem but I know of no major impacts to my tires and they have only about 5000 miles after I returned home. Tread is good on all tires and I see no reason for a tire to just explode while traveling. I run about 5mph below the speed limit in the right lane. I had the trailer weighed after loading up for a trip and I am well within limits. Tires must be able to withstand the heat and road conditions all across the country. We don't have glass smooth roads to be built to accommodate poorly made tires
I have heard of other incidents with are same and I believe these tires should have never been original equipment on an expensive fifth wheel camper.
I will replace all 4 tires after my insurance adjuster inspects the damaged tire. there is some damage to the trailer as well. Wheel skirt and J wrap is damaged and the insulation under the floor above the wheel well is torn out. I was lucky to be able to finish my trip without the camper being disabled on the road. The trailer brake wiring remained intact.
If you have these Chinese tires on your camper I would recommend that you change them out before you experience a similar incident. I was told Goodyear Advantage is a good trailer tire by my local tire guys.I think I will go with them after some more tire research.
All the best and stay safe on the road.
Solman
Solman
