tinner12002
Dec 10, 2016Explorer
I'd also recommend the Maxxis tires, have had great luck with mine. As for deflection, part of the reason ST tires don't have as much deflection as LT tires is because the ST tires are designed to be scooted sideways when turning and backing so sidewalls are generally stiffer to keep tires from rolling off the rim, thus the higher weight rating of ST tires. Manufacturers use STs predominantly for a reason, and its not so you'll have more blowouts. They just haven't made good choices in the brands that they use. I've seen LTs used on car trailers and when they turn it looks like the tire is ready to roll off the rim...not a pretty site for sure! In my opinion, a lot of people use the LTs just so they can run as fast as they want without having to worry about the speed rating on the tires. Of course some will argue that comment too.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 23, 2026
