DannyA's avatar
DannyA
Tire monitor system question
Looking at getting the TST system and know they recommend metal valve stems but wondering how many have not changed to metal stems and any problems using the ones that came on there.
It came with nitrogen in the tires and I hate to change that out if I don't have to.
    I did not change mine, however I think it depends on the valve stem. My valve stem is recessed into the aluminum wheel and when I put the sensors on the stem it barely moves. It the valve stem sticks out a bit you may end up with problems.
  • I guess it depends on your comfort level. I would put on the metal valve stems and use the 80% nitrogen mix.
  • You can use the OEM valve stems until they get old and leak then replace with metal. Nitrogen in the tires has been discussed in this Forum.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
