kellertx5er
Jun 19, 2015Explorer
the bear II wrote:
Here's an example:
The company I work for has a fleet of vehicles we can use when going out in the field. One is a chevy 2500 long bed extended cab. Originally from the factory it came with load range c tires with a max PSI of 35. That's what the data plate shows on the door. When the tires were torn up on a rocky road, they were replaced with Load Range D tires. The sidewall shows max is 80 PSI
Similar with a Jeep Cherokee. The tires were replaced with a higher load range tire.
That being said many tire manufacturers on their websites provide charts which indicate the acceptable PSI based on the actual load.
I always keep my tires inflated to the Max PSI indicated on the sidewall. I don't have the time to adjust the pressure depending on load I'm carrying.
Sorry, but this is not much of an example. You failed to give any facts which support the decision to inflate to max PSI. It only seems that load range C tires were not suitable for the job.
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Sep 04, 2018
