mowermech
Jun 19, 2015Explorer
Anytime I see this issue, I refer to the Jeep Wrangler Rubicon Unlimited I once had.
The tire data plate said inflate to 33 PSI for max GAWR.
The original tires, installed at the factory, were Load Range E, with a max sidewall pressure (for maximum load) of 80 PSI.
So, apparently, some guys are saying that I should have inflated the tires to 80 PSI, even though there was no way the Jeep would EVER be loaded to over 3000 lbs. per tire.
Actually, I ran those tires at pressures as low as 12 PSI when off-roading.
I never inflated them to more than 33 PSI, as recommended by Jeep.
There is no way I would EVER inflate the tires on the Southwind to the max pressure shown on the side wall. The thing would ride like a logging truck!
I follow the vehicle manufacturer's inflation recommendations.
YOU, of course, are free to do what you want with YOUR tires!
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Sep 04, 2018
