dcmac214's avatar
dcmac214
Tire Pressure - MAX vs DATAPLATE
A LOT of replies to tire threads recommend running the trailer (and I assume also car/truck/motorhome) at sidewall max psi instead of the dataplate psi. Why?
My trailer tires have a max psi of 120. The trailer dataplate tells me the correct psi is 80. So I follow the manufacturer recommendation 80psi. I figure they know better than anone else what's 'right' for my trailer.
What benefit(s) would I get running sidewall max 120psi?
Same with my car & truck. Dataplate psi is about half the sidewall max. There may be a noticeable savings in fuel mpg running tires at sidewall max but the ride would probably be so hard as to be quite uncomfortable and I would assume tread wear would be much quicker. And I'd also assume there would be problems with the tire maker if I tried to make a warranty claim while running sidewall max instead of vehicle dataplate psi.
  • 120 psi?? What is the tire designation on the trailer tires and brand? Big difference in what to do between tire types and what they're on. Are the tires presently on the trailer the same as what's on the placard? They can be different and if run too low, serious damage from heat can occur.
    Go to RV tire safety dot com and read about ST tire inflation from a tire engineer.
  • Here's an example:
    The company I work for has a fleet of vehicles we can use when going out in the field. One is a chevy 2500 long bed extended cab. Originally from the factory it came with load range c tires with a max PSI of 35. That's what the data plate shows on the door. When the tires were torn up on a rocky road, they were replaced with Load Range D tires. The sidewall shows max is 80 PSI
    Similar with a Jeep Cherokee. The tires were replaced with a higher load range tire.
    That being said many tire manufacturers on their websites provide charts which indicate the acceptable PSI based on the actual load.
    I always keep my tires inflated to the Max PSI indicated on the sidewall. I don't have the time to adjust the pressure depending on load I'm carrying.
  • Benefit is (slightly) improved fuel mileage. But the cost is uneven tire wear leading to early replacement (not an issue on RVs which generally need new tires due to age long before the tread wears out); rough/bouncy ride (again, not so much an issue on a vehicle in which nobody is present and "stuff" is all tied down); slightly poorer traction/cornering ability; and slightly higher blowout risk.
    Bear in mind that there is controversy over the issue BECAUSE the differences either way are relatively small.
Looking for advice before your next adventure? Look no further.25,163 PostsLatest Activity: Sep 11, 2025
