harley-dave
Mar 09, 2016Explorer II
Gonzo42 wrote:Don't put to much faith in that door jam sticker! My sticker recommends 73 lbs. 73 lbs, got to be kidding! We're near or at max gross on our 31' C so its 80 lbs on all tires. Only a scales can tell you for sure what to air the tires to. I went to a CAT scale at a truck stop the first time, what a surprise that was... Since then I've had it weighed at one of the escapees smart weigh sites. We're better now.
There should be a label near the pilot's door specifying the tire pressures for front, rear and spare.
If you don't already have them, I recommend the valve extenders, which are steel braided lines that look like brake lines and give you easy access, especially to the inside pairs.
I had the braided extenders until one had the rubber inside fail and I could not fill or check pressure any more. I went to Borg stainless steel extenders and have had good luck with those. Kind of depends on which you prefer I think.
Dave
Looking for advice before your next adventure? Look no further.25,180 PostsLatest Activity: Jan 22, 2026
