4x4van
Mar 09, 2016Explorer III
As several others have said, go get your RV weighed, front and rear axles separately at least, then use a tire chart to determine correct pressures. I used to run 55-60 front and rear. Weighing/chart showed that I SHOULD have been running only 45 in the front. I dropped the front to 45psi, and the handling improved significantly.
Looking for advice before your next adventure? Look no further.25,180 PostsLatest Activity: Jan 22, 2026
