Bobbo
Jan 12, 2016Explorer III
fj12ryder wrote:Bobbo wrote:If you lose contact with the sensor you'll have no idea whether you have pressure loss or heat buildup. You can lose contact with the sensor just driving down the road if you have a long unit, and you'll have no idea until the monitor alerts you that you've lost contact. That can take an hour or more. During that hour you can blow a tire or have pressure loss and not know it.
I don't mind waiting an hour to learn the battery has died in my TPMS sensor.
As long as it alarms quickly on pressure loss or heat buildup.
I like my TST but I think this time lag issue should be fixed.
That is 2 failures at the same time. A highly improbable occurrence. I will risk it without losing any sleep.
By the same token, If you have a circuit breaker in your house fail and lock closed, and at the same time have a dead short in the wire, you can have a house fire. Is that a design flaw?
You have too much time on your hands.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 17, 2026
