fj12ryder
Jan 12, 2016Explorer III
Bobbo wrote:I don't think you understand what I'm typing. No failure anywhere, just the way the system is designed to work.fj12ryder wrote:Bobbo wrote:If you lose contact with the sensor you'll have no idea whether you have pressure loss or heat buildup. You can lose contact with the sensor just driving down the road if you have a long unit, and you'll have no idea until the monitor alerts you that you've lost contact. That can take an hour or more. During that hour you can blow a tire or have pressure loss and not know it.
I don't mind waiting an hour to learn the battery has died in my TPMS sensor.
As long as it alarms quickly on pressure loss or heat buildup.
I like my TST but I think this time lag issue should be fixed.
That is 2 failures at the same time. A highly improbable occurrence. I will risk it without losing any sleep.
By the same token, If you have a circuit breaker in your house fail and lock closed, and at the same time have a dead short in the wire, you can have a house fire. Is that a design flaw?
You have too much time on your hands.
If your monitor loses contact with a tire sensor, which is more likely if you have a long trailer, you won't know about it for around an hour. During that hour you will not know if your tire loses air, runs hot, or goes completely flat. The monitor will show the last temperature/pressure that it received, which could be an hour old. That is the way the TST system works.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 17, 2026
