mrp116's avatar
mrp116
Tire Pressure Question
I currently have a 2012 Toyota Tundra with the factory Michelin LTX/AS 275/65/18 tires aired up to the factory specs in the low to mid 30 psi range. In a couple weeks, we will be picking up our first TT (upgrading from a pop-up where psi wasn't that big of a deal with the TV) which is a Jayco White Hawk 28dsbh, and it will arrive from the factory with a dry weight around 5,700 - 5,800 lbs. I have read posts about airing up to tow, but I haven't seen what the optimum level is. What tire pressure should I run while towing?
  • Weigh the axles use the tire inflation chart for your tires and apply what you read plus 5psi.
  • Looks like your tires are rated to carry a max weight of 2601 per tire. How much weight will be on your tires with the trailer hooked up? If it's not 5202 pounds then I wouldn't take it up to max pressure as that can be as bad as being under inflated. Michelin has an inflation chart for the actual amount of weight involved.
  • Air them up to the max. pressure that is listed on the tire side wall or since they are factory installed original tires - look on the driver's side door jam for a placard and air them to the max shown there.
    Sometimes there will be a different psi for front and back tires.
    Max psi will give you the max rated payload for your tires.
    Enjoy your new rig.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 10, 2026
