Turtle_n_Peeps
Jun 11, 2014Explorer
I personally go max pressure even on E rated tires and here is why.
1. I tow in hot weather (90 degrees is the norm) and the more pressure means less heat and less chance for tire failure.
2. The higher pressure you go means better fuel mileage and that is always a good thing. Now I know this is a very small effect but every little bit helps when towing.
I know that some will disagree with my max pressure advice and show load pressure charts and all of that and that is fine but max pressure works for me.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: May 29, 2026
