BarneyS
Aug 22, 2016Nomad
I have always run my trailer tires at maximum sidewall pressure and have never had a single tire related problem. I would recommend you run yours at 65psi.
I have two main reasons for saying that.
1. Most trailer tires are just adequate for the load they are carrying. There is usually very little capability to spare.
2. The higher pressure will make the sidewalls stiffer which helps keep sway down and also helps keep the tire on the rim when doing tight turns that scuffs the tread along the road. This does not happen on single axle trailer but most travel trailers of any size have two or more axles and will scuff the tread when turning. The bigger the spread between the axles, the more scuffing will take place.
Barney
Barney
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 19, 2026
