What's the consensus on Max tire pressure when towing 10K. Generally I run max tire pressure as rated on the tire for both the trailer and tow vehicle, with the exception of the front tires on the ...
I spoke with a Bridgestone engineer a few years ago about tire pressure. Engineer said to run tires at max (cold) air. He advised running max air will eliminate possible blowouts. Just do not go over weight rating for tires. I also asked, if I run max air, will the tires blow with they heat up while driving. Engineer said tire will not blow. The tires are built to handle the max (cold) air.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 17, 2025
