1L243Explorer IIOct 23, 2020Tire PressureWhat's the consensus on Max tire pressure when towing 10K. Generally I run max tire pressure as rated on the tire for both the trailer and tow vehicle, with the exception of the front tires on the ...Show More
notevenExplorer IIIOct 24, 2020I run load and inflation table pressure. Sometimes that is “max psi” depending on the load. If you change tire load index or size from what is on the sticker the sticker no longer applies.
About RV Tips & TricksLooking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 17, 2025
