1L243's avatar
1L243
Explorer II
Oct 23, 2020
Tire Pressure
What's the consensus on Max tire pressure when towing 10K. Generally I run max tire pressure as rated on the tire for both the trailer and tow vehicle, with the exception of the front tires on the tow vehicle I run about 5 lbs under max tire rated pressure because I think the front runs a little light when towing.
  • Weight the axles and set the pressure according to the tire mfg load inflation tables.
    I've often weighted at the free OR scales.
  • The pressure that gives the tire its max weight capacity.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
