Super_Dave's avatar
Super_Dave
Explorer II
Nov 01, 2020
Tire pressure?
Where do you get your 110 psi? Wondering where to take the 5th wheel to get the tire pressure back up. It has been a few years and they are down to around 90 psi.
  • Run your tire pressure to max PSI rating on tire, cold.
    Check your tires before each trip.
    I carry a Viar compressor but never had to use it on road.....because I check tires before each trip and take them back to max.
    Well here’s proof that y’all that are OCD to +\- 1 psi, do I fill in the morning or evening, rotate the tires into or out of the sun, etc, might be just a bit too fixated on the merits of exact tire psi.
    Rock on Dave!
    On the flip side, I have like find it difficult to function around the house without a good air compressor.
    Sounds like it’s time to buy one. Or stop by a tire shop. Free air, as many psi’s as you can fit in your tires!
  • Lwiddis wrote:
    RVing without the ability to inflate all your tires to the recommended air pressure in a dry campsite isn’t wise.
    Maybe not as convenient, but unwise??
    Cmon man...
  • Anonymous's avatar
    Anonymous
    Not applicable
    ktmrfs wrote:
    two stage home compressor, 175psi max
    X2
  • What tires are you running that require 120psi. I don't even fill my 22.5" class A tires to that pressure. I run them at 87psi, per the weight of the coach and the tire manuf weight/pressure chart.
    That's why a Via Air Compressor is in basement.
  • RVing without the ability to inflate all your tires to the recommended air pressure in a dry campsite isn’t wise.
  • Any tire shop.
    Or if you have a decent sized portable AC, you can get 120-130+ psi out of them.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
