Cube58's avatar
Cube58
Tire Presure Monitoring System
Hi All. What are you people using. Reliable Signal, Problems. Please be sure to include your Make & model. Thanks. :)
  • TNSnowbirds wrote:
    We also have the 507 and they worked great on our trip south...First system for us and it was nervy watching the temp go up to 101 deg and the TP go up to 121. Now I've got to do a survey and get some pressures and temps that are normal for the Goodyear G614's at 110 psi and a 15k trailer so I can get my breath next time....
    generally pressures go up 10% when hot. so 110 +11 = 121
    sam
    still have to move my TireMinder to the FW
  • I have the TireMinder system for the coach and the toad. I had a couple of bad sensors at the start that they replaced quickly. They have great custiner service and they have been working great.
  • Tire Minder on the 5th and Swivel Wheel in my sig.
    The tires for Swivel Wheel are way out back.
    I use a Tire Minder booster in the kingpin.
    Works well. Good customer support. Free replacement of batteries.
  • We also have the 507 and they worked great on our trip south...First system for us and it was nervy watching the temp go up to 101 deg and the TP go up to 121. Now I've got to do a survey and get some pressures and temps that are normal for the Goodyear G614's at 110 psi and a 15k trailer so I can get my breath next time....
  • TST 507RV with 12 sensors. Works well without repeater even from the spare mounted under the rear of the trailer. Changed batteries after 2 years. No failures. Great customer service. Sent all new Orings free of charge when I changed the batteries.
  • TST 507RV. Works great. User replaceable batteries. Flow thru sensors also available.
  • Tire Treker. Good product. Good customer service. Can replace sensor batteries instead of replacing sensors. Highly recommend them. Easy set up.
  • I am using the Pressure Pro system. It works great although I have one sensor that doesn't always read. Pressure Pro said they would replace the sensor even though it is slightly out of warranty.
    The company I bought from had the system on the shelf for several years. That is certainly no fault of Pressure Pro.
  • Already done. Search this Forum for `tpms' or `Pressure Pro' etc.
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 05, 2026
