1. After reading the tire issues with the Goodyear Marathons I decided to check the tires on my 5th wheel Montana. I have the Goodyear Marathons, size ST 235 80 R16E, on my RV. The tires have good ...
So your trailer has a GVWR of 14000 pounds, what is the GAWR? If it has 6K axles, which I believe it does, I would be installed Michelin XPS RIBs or Bridgestone Duravis R250 to put tire problems behind you!
Go over to the Montana Owners Forum and learn what others have found to be the best solution for that trailer.
Chris
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: May 12, 2019
