Are there weight ratings for rims on our 5th wheels. if so how does one figure those out? i purchased a new rim and wanna make sure its got correct weight rating/
PSI rating should be stamped on the inner rim. Weight rating? Where you bought it from should be able to tell you load rating. Generally speaking 80PSI should equate to around 3200 pounds load. Whereas 110PSI rating would be around 4000+ pounds load rating.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 02, 2025
