I have a 2012 Honda Ridgeline and plan on towing a 2019 R-Pod that weights approximately 2967lbs. I am asking if certain tires and shocks can help with the towing. Also my old hitch was for larger a...
The tires should be ok but if you want to get new ones I would look for the same size and type that came on it. New shocks on the truck would probably help as they are getting a bit long in the tooth.
For a hitch, the Andersen hitch might be a perfect fit. Easy to use and lightweight to move around. Would probably reduce any tendency for the rig to porpoise - especially if the shocks are worn on the truck. Barney
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 18, 2026
