lawrosa
Oct 10, 2013Explorer
Its not the GVWR of the travel traler but the tounge weight. You factory tires are rated most likely for your axle rate and its just a mater of correct air pressure in the tires. They most likely fine for the payload capacity of the truck.
Look on the sidewall of your tires and post back the weight rating at max PSI. Then open the door and look at the rear axle weight and tell use that #...
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 17, 2025
